Erata
04/20/2016 at 12:19 • 0 commentsFound a footnote call out without an actual footnote. Initially I had intended to use the Ben Franklin bit as a footnote, but since I put the Ben Franklin bit in the body of the article, I removed the footnote call out.
Corrections
04/19/2016 at 19:17 • 0 commentsThe project description was poorly formatted. Replaced, first line of details with "I'll explain some simple diode functions using Snap Circuits." and now the search description text looks much better.
