I have completed 8 bit planes, ready to assemble into a 8 x 8 x 8 bit (64 byte) stack:
Just waiting on some standoffs, cables and headers. Here's a closeup view of a plane showing the drive line connectors (1mm pitch FFC) and the sense and inhibit connectors (2-pin JST):
Finally, a view of the underside of the bottom plane, showing the pin connectors that plug into the carrier board:
Meanwhile, I am workng on the schematic for the carrier board, on which will be mounted the core stack and the logic shown in the diagram in the project details.
It's just about enough for a bootloader, so that's all the non-volatile storage you need.
Ha! Well, for a stack, it's plenty. For system RAM, well, it depends on what you are doing :)
BTW, do you ever sleep, Yann? :) Or do you just go into suspend mode for a couple of hours?
64 bytes should be enough for ... wait.... never mind :-D
