Reading, writing, and repairing.
The last few weeks have seen significant progress, to the point where I can read and write data to the the cores, with the following limitations:
1. I screwed up the design of the Inhibit module, so I can only write 1 zero in a byte. I have corrected the module design, and I expect the corrected boards to arrive any day now.
2. The system currently takes about 30 mins to warm up. If I run a continuous memory test on the cores (writing 0xFFs/0xEFs), a serial printout of erroneous memory locations gradually gets shorter and shorter, until they're all ok. I'm not sure what the issue is, but I suspect the bias diodes (1N4148s) in the sense amplifiers. The sense amplifiers are a bit kludgey, so I'm reluctant to disturb them too much until I have corrected boards for them - the next job, after the inhibit module. Then I can investigate properly, without worrying about breaking shitty soldering joints or shorting kludge wires.
Anyway, here's a few pics of the current setup:
In the picture above you can see my Quality Assurance Technician (QAT) hard at work.
The rear of the memory system, currently controlled with a Arduino Mega 2560, and the power supply. Note the cat-5e cables - this is how the various computer subsystems will be interconnected.
The quality assurance technician's work is not to be happy...
Of course not, she isn't being fed at that particular moment :)
obviously not :-)
"The F is this shit? I'm writing you up!"
Where do you get these fine boards manufactured ?
pcbway.com. They're the one of the cheapest board houses out there, and the quality is good.
your base boards are quite large, how much did they cost ?
The base boards are 275 x 177mm, 4 layers. Currently US$216 for 5, including freight to La Belle France :)
Meow...
Damn thing is a camera hog
