Done and dusted
A project log for Ferrite Core Memory Module
A sub-project of the ED-64 Computer to document the development of a 64-byte ferrite core memory module
andrew-starrAndrew Starr 04/22/2017 at 06:033 Comments
The components for the Inhibit driver arrived yesterday. I populated the module, plugged it in, connected the inhibit lines, and loaded the arduino with a checkerboard memory test I wrote a couple of weeks ago.
And....it works!
No memory errors after 100,000+ iterations, each iteration consisting of writing a pattern byte (0x55 or 0xaa) to all memory locations, then reading all memory locations, checking the data read against the pattern.
This project is now complete, and I can move on with the rest of the ED-64 build. Yay!
Yann Guidon / YGDES wrote 04/22/2017 at 07:24 point
0x55 and 0xAA are nice but only 1/128 of the coding space.
Now, use a 32-bits LFSR ;-)
Blair Wyatt wrote 04/23/2017 at 02:11 point
Those values do test the most extreme condition though; a full state change for each bit with an alternating bit pattern (10101010 -> 01010101).
Yann Guidon / YGDES wrote 04/23/2017 at 02:16 point
well, it depends...
