Hackaday.io Hackaday.io
Sign up Log in
RamuDroid
bot to clean roads
altanaialtanai
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1 comments
1.3k followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 7
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 1
  • The 2016 Hackaday Prize
View Gallery
874
1
1.3k
11
Team (3)
  • altanaialtanai
  • deepak-aagriDeepak Aagri
  • abishtabisht
Join this project's team
  • m2m communications
  • presentation
  • demo
completed project
2016HackadayPrize iot WebRTC livestreaming ai Robotics
Related lists
2016 THP: Atmel Parts
Hackaday Prize Entries using Atmel parts
robots
robotics n innovation
This project is submitted for
  • Hackaday.com Tip Line
  • Get Started: Design Your Concept
This project was created on 04/21/2016 and last updated 9 years ago.
Description
The purpose of this Droid is to clean roads and outdoors for a better and cleaner India. It works on the principle of aerodynamics to left up small objects like plastic cups, wrappers , leaves etc. The droid also provides realtime streaming through a front faced camera, remote navigation and detects obstruction to reroute itself. It communicates to remote control center over 3G and .The user can control or navigate the droid via their browsers also.
Research is ongoing to make it even more autonomous in tough terrain and hostile conditions . We are also actively looking at image processing algorithms to provide waste segregation ( recyclable and non-recyclable ) on the collected garbage.
The technology stack is build such that it can be used for any machine like drone , kiosk etc.
Files
Hackaday Ramudroid (1).pdf
Adobe Portable Document Format - 8.35 MB - 04/26/2016 at 13:22
Preview
Components
  • 1 × raspberry pi
  • 1 × arduino
  • 1 × ultrasonic sensor
  • 1 × bluetooth low energy
  • 1 × wifi module
View all 7 components
Project Logs
Collapse
  • RamuDroid
    altanai • 04/24/2016 at 11:28 • 0 comments
View project log
Log In/Sign up to comment
Sign up with Github
OR
geekstips wrote 12/16/2016 at 06:50 • point
What wi-fi module? Is a ESP?
Supplyframe DesignLab: 2022 Hackada…
Sliding facade pieces that can move according to sunlight or by control to change the building view or hiding view like curtain or etc.
Project Owner Contributor
Smart Facade of The Building
shahram-samadpourbonabShahram Samadpourbonab
Bosch SCMS station with dust shute under that collects the dust with suction and a story rod for repetitive smaller cuts beyond the t-track
Dust control on a Bosch Glide SCMS
macduff2macduff2
The 2017 Hackaday Prize
Prevent accidental shootings and suicides.
SmartMag
jacobJacob
Official Hackaday Prize Entry
Control any TV, set top box, stereo or any other device which uses an IR remote through your smartphone with Speech Recognition!
Aergia: Android TV Remote(with Speech Recognition)
jayvis-gonsalvesJayvis Gonsalves
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "RamuDroid", please tell us the reason.
Send message
Remove Member
