The idea is to have a FM receiver chip with I2S interface to get the audio data into the digital domain as quickly as possible. The FPGA implements a ring buffer inside the SDRAM memory with an I2S to line out back end. A small controller, probably Arduino is going to to control the radio station and a small display with a all necessary information as FM frequency, rewind metric and memory telemetry. Finally the main controller, a BIG red button to rewind your radio and give superior listen experience.
The concept changed somewhat, I decided to run the analog audio rom the FM reciever chip to the audio processor and use its I2S interface as the only digital link. Makes for a much cleaner data flow.
The base platform is going to be a Digilent ARTY S7 board which provides 256MB of SDRAM already, so I don't have to do the risky SDRAM over PMOD interface. The daughter card with all audio circuit will be in a Arduino Shield formfactor for potentially later re-use.
The design and layout is finished, schematic (with fixes) and assembly drawing are in the files section.
And to fill in some gaps: With 256 MB of memory all used in one big ring buffer and assuming 44.1 kSamples/sec, my math adds up to just under 25 minutes of rewind time, which should be plenty.
MagicWolfi
Jason Nelson
Michael Kafarowski
Michele Perla
You could also use RDS to implement commercial skipping.
