Version v3.0
A project log for Raspberry Pi Zero Breakout
A break out board for the Raspberry Pi Zero for use with 5v signalling, and featuring a full size USB-A socket
david-brownDavid Brown • 05/02/2016 at 13:43•0 Comments
I've uploaded version v3.0 of the board which has the headers moved to prevent clash with the micro USB connector on the Pi. I have also added a PolyZen over voltage protection diode to the 5V inlet to add a degree of over voltage protection.
Before I killed the Pi, the wifi adaptor plugged directly into the v2.0 board was working happily through the pogo pin connection to the header pads on the Pi.
