This process is taken from Howto: Raspi HAT EEPROM and device-tree but corrected for a couple of syntax errors (using Raspbian).
As a preliminary step, you need to activate videocore I2C. This is done by adding a line at the beginning of your /boot/config.txt file
sudo nano /boot/config.txtthen adddtparam=i2c_vc=onreboot
First of all, you need to get EEPROM utils (to make EEPROM content and flash it) and device-tree compiler (dtc).
git clone https://github.com/raspberrypi/hats.git
sudo apt-get install device-tree-compilerYou'll have now installed dtc compiler and have a hat directory. Go inside, and open eepromutils directory and compile the eepmake file.cd Downloads/hat/eepromutils
sudo makeThen modify eeprom_settings.txt to create your own version of HAT board. You don't have to modify the UUID, as it will be auto-generated.
sudo nano eeprom_settings.txtThen, you can create an eep file, based on you eeprom_settings.txt file. Basically, an eep file is a binary version of this file, which is ready to flash on EEPROM.
sudo ./eepmake eeprom_settings.txt myhat.eep
You have now a working HAT file!
You can now write it on EEPROM. If you have followed the design guide, you have a 24c32 memory (4k). But your myhat.eep file is smaller. As you don't know the state of your EEPROM, you may have conflict, as your myhat.eep could be misread. To avoid that, we shall start by cleaning the EEPROM.
Use this dd command to generate a 4k file, padded with zero (an excellent choice, zeros are my favorites!). If you have another EEPROM size, just change count value according to your real EEPROM size.
sudo dd if=/dev/zero ibs=1k count=4 of=blank.eepTo be sure, you can review this binary, using hexdump :
hexdump blank.eepNext, you can now upload it to your EEPROM :
sudo ./eepflash.sh -w -f=blank.eep -t=24c32Answer yes and wait. The write protect is disabled by the small ground trace and once programmed can be cut and the write protect soldered closed.
To verify if everything went well, you can use this command to check EEPROM content. Caution: it will only work after you use the eepflash command, which does some modprobes.
sudo hexdump /sys/class/i2c-adapter/i2c-0/0-0050/eepromIf everything is okay, you'll only see zeros.
Then, you can upload your own myhat.eep.
sudo ./eepflash.sh -w -f=myhat.eep -t=24c32And again, verify it after uploading :
sudo hexdump /sys/class/i2c-adapter/i2c-0/0-0050/eepromIf the contents match, you can reboot your Raspberry Pi.
To check if your HAT is recognised, just go to /proc/device-tree/. If you see a hat directory, you are a winner:)
cd /proc/device-tree/hat/
more vendor
more product
Nice one!
Hi, interesting!, as i can do to check data EEPROM at the start of the Raspberry, call a script from the etc/rc.local ?. Thanks
The Raspberry pi will automatically read the content of the EEPROM on startup and set the pin assignments as directed. I would advise looking up the official implementation on; https://github.com/raspberrypi/hats and also the guide linked above.
