Micro Python firmware on OHS 18 eve
09/27/2018 at 02:50 • 1 commentFind out more about the Open Hardware Summit (@ohsummit) badge hardware design and MicroPython firmware by visiting @hackadayio project page and join our project chat room https://t.co/YVHboC3OGp #ohsummit18 https://t.co/swbvn19DZH
Live from Artisan's Asylum!
09/26/2018 at 02:22 • 0 comments@Alex Camilo , @AVR , @Jimmie Rodgers , @Andrew Sowa and I are all at Artisan's Asylum tonight and the badge firmware is coming together quite nicely!
https://twitter.com/oshpark/status/1044733583972356097
Thanks so much to Artisan's Asylum for giving us space to bring this badge project to completion!
Tomorrow night (Wednesday):
Pre Open Hardware Summit meetup and Fellowship fundraiser https://www.eventbrite.com/e/pre-open-hardware-summit-meetup-and-fellowship-fundraiser-tickets-50343178803
Thursday:Open Hardware Summit!
Demo of e-paper using Arduino libraries
09/17/2018 at 23:12 • 0 commentsThe official firmware will be MicroPython-based. However, I wanted to document an Arduino sketch and libraries that can be with the e-paper display on the bage.
The GitHub repo is here:
https://github.com/oshwabadge2018/arduino-epaper-demo
Instructions:
- Install the latest Arduino IDE and add the ESP32 board options to the Board Manager:
- Make sure the board is set to "ESP32 dev module"
- Make sure the serial port is the serial adapter.
- Wire up GND, RX, TX to the FTDI.
- Connect the IO0 pin to GND.
- Insert Batteries
- The module should power up and go into programming mode (IO0 low on powerup or reset)
- Click program in the Arduino IDE.
- The board should program.
- Un-ground IO0 and remove and reinsert the batteries.
- If this does not work then swap RX and TX and repeat the process
Methods to connect the wires:
- remove battery back to expose the bottom of J1 header and solder a 6 pin header on J1
- solder wires to J1 on the front the badge (and leave battery pack in place)
- use a 6 pin pogo pin adapter. I used an AVR ISP pogo pin adapter and connected to an 3.3V FTDI cable from Adafruit
- gallery of photos: https://photos.app.goo.gl/rP3fTZDd6UUGbDtt9
(I may try to do a diagram in the future, but wanted to link to photos in the meantime)
Screaming Circuits shipment has arrived
09/11/2018 at 16:36 • 2 commentsAll 300 badges assembled by Screaming Circuits have arrived!
Photo gallery: https://photos.app.goo.gl/Ficbod1XqiMPB1P66
Thanks to Duane Benson and the rest of the team at Screaming Circuits for all the support on this project.
Custom Lanyards for #ohsummit18
09/10/2018 at 22:34 • 0 commentsThanks to @Zapp @Hyr0n and the ANDnXOR badge team for the suggestion of custom printed dye sublimation from CustomLanyards4All. We selected the doubled ended lanyard with plastic j-hook upgrade to avoid the metal hook from shorting out any connections:
https://www.customlanyards4all.com/double-ended-lanyards/ldeds-2-detail
We ordered quantity 330 lanyards to have some extra in case of any issues. The planned number of badges is 300.
The shipment just arrived today!
Photos of final PCB revision
09/10/2018 at 22:03 • 0 commentsThe boards are currently being assembled by Screaming Circuits thanks to a generous offer from Duane Benson.
Here is what the final PCB looks like (rev 4):
OSH Park shared project:
https://oshpark.com/shared_projects/bIhaGuzO
KiCad design files and gerbers on GitHub:
https://github.com/oshwabadge2018/ohs18badge/releases/tag/Rev4
Rev 3 ordered and Rev 2 photos
08/06/2018 at 11:45 • 4 commentsOSH Park shared project for the Rev 3 by @Alex Camilo :
https://oshpark.com/shared_projects/8yeLK5gd
We expect this to be the final revision.
Timeline:
It is ordered on Super Swift today and should be validated next weekend. This will allow us to order the full quantity PCB panels in August 13th. Assembly is estimated to be 10 business days from the day when all components and PCBs are received.
Rev 2 photos:
And for those interested, here is a link to a gallery:
https://photos.app.goo.gl/UhCUX7eRN38tAhsF7
Terminal output on Rev 2 prototypes:
The Rev 2 prototypes have NodeMCU boards soldered on to the back to serve as a USB to serial adapter.
One of the Rev 2 prototype boards that Alex sent me has the default e-paper demo:
The other has MicroPython installed! :)
OHS18 badge certified as OSHW
08/03/2018 at 18:01 • 0 commentsOpen Hardware Summit 2018 badge has now officially been certified as open source hardware by the Open Source Hardware Association.
UID is: US000133
Also, @Alex Camilo created a this GitHub repo to act as the OHS18 Badge Documentation website: Page
OHS18 prototype by Alex Camilo
08/03/2018 at 17:57 • 0 commentsquick update for those that have not been following along with this project's chatroom.
@Alex Camilo has been doing FANTASTIC leading the design of the OHS18 badge!
Here is video of prototype designed by @Alex Camilo : https://www.youtube.com/watch?v=GLpCBzm6ff0
Photo of Rev 2 prototype:
And here is render of preview of our Rev 3 prototype:
Custom Lanyards
05/29/2018 at 18:02 • 5 commentsI got this suggestion from AND!XOR for custom lanyards:
https://www.customlanyards4all.comThey recommended doing
"DYE SUBLIMATION LANYARD"
https://www.customlanyards4all.com/dye-sublimation-lanyards/dye-sublimation-full-color-detail
Any thoughts about width?
I think I'd like either 1" or 3/4".
Thanks,
Drew
