(WARNING - purely conceptual project at this stage)
This project is largely to fill an existing need - I rent my house, and can't exactly start rewiring fittings or switches to provide some decent monitoring or automation. As such, this project has two main goals:
- Be completely retrofittable, no house modification necessary (no holes in walls, doors, or rewiring things).
- Doesn’t require a significant initial investment in the system to start using the most basic functions (looking at you, Belkin)
To achieve this, we're looking at a similar basic topology to many existing systems - a central hub that acts as a bridge between the local WiFi network, and the much lower power, lower bandwidth mesh network that the automation nodes communicate on (fairly common in these systems). A separate low power wireless network is going to be critical to meet the goals, as many of the nodes that can't be powered from a wall socket will be battery powered by necessity (and who wants an automation system that requires running around the house changing it's batteries every couple of days?). We appreciate that there are plenty of systems already out there (a quick search on Hackaday.io shows…..3218. Holy crap), and so a large chunk of the initial work will be reading through a bunch of those to try and see what can be reused. We'll also start looking at some existing hardware, to see how viable it might be to convert existing products.
A quick rundown on the sort of stuff we’ll be targeting first:
- Standalone sensors (light, temperature, movement)
- Inline IR transceivers (to control appliances)
- Inline adapters for light sockets
- A centralized networked control interface
All hardware and software designed as part of this project are licensed under a Creative Commons Attribution-ShareAlike 4.0 International License
novirium
electronicsworkshops
Luke
Guillermo Perez Guillen
