Open Exposer and PCB exposing
A project log for OpenExposer
An affordable Arduino controlled multipurpose laser exposing device. Use it for SLA Printers, PCB Exposing, Laser Harp etc.
mario-lukasMario Lukas • 06/10/2014 at 08:43•0 Comments
After the Makerfaire in Hannover (Germany) i will start to build the PCB exposing extension. It should work like a laminator by pushing the copperplate through the Open Exposer unit. All parts will be 3D printable or laser cutable. The following rough sketch will give you an idea.
