Assembly of the new z-axis
05/27/2014 at 08:00 • 0 commentsYesterday i assembled the new z-axis. It is more stable now. The only thing i have to do is redesigning the build stage. Then i will do a first printing test this weekend.
Z axis improvement for 3D printer application
05/25/2014 at 23:09 • 0 commentsToday i printed a new z - axis solution for the OpenExposer 3d printer module. I will give it a try tomorrow. It should be more precise now.
Bay Area Maker Faire Made Solid Printing Resin
05/19/2014 at 15:20 • 0 commentsYesterday i visited the Bay Area Maker Faire. In the Start Up Area i found the booth of MadeSolid. They produce their own printing resins. I told them of the OpenExposer project and got a sample bottle of resin. I will give it a try when i am back in europe.
First exposing experiments with OpenExposer used as a component for a 3D printer
05/13/2014 at 15:54 • 0 commentsThe first two pictures are showing the results of printing a 8mm x 8 mm x 2 mm cube. On the third picture you can see some of the first exposing experiments.
Using OpenExposer as part of a 3D printer
05/13/2014 at 15:45 • 0 commentsFor testing purposes of the OpenExposer unit, i am building a 3D printer.
Reverse Engineering of several polygon mirrors
05/13/2014 at 14:52 • 0 commentsIn November last year, i reverse engineered several polygon mirror units of some laser printers i've got from friends. I also ordered some further units from ebay. Now a attiny2313 regulates the mirror motor speed. The attiny2313 should be a part of the openexposer (shield) or arduino compatible board later. Then it should be possible to configure the used polygon mirror unit by jumpers or a firmware flag.
