Open Exposer Arduino shield.
01/25/2016 at 21:24 • 0 commentsAnd here it is! Today our manufacturer delivered a first prototype of the Open Exposer Arduino shield. I am at the hospital at the moment, but hopefully i can leave this friday. When i am back at home i will solder it! Keep on reading...
We are still working on this project!
12/21/2015 at 09:10 • 2 commentsYesterday i made some breakout boards for a laser driver ic ( IC-HKB ) from ic-haus.de
This small part will replace the self made laser driver which was based on the die4drive
laser diode driver. The IC-HKB supports laser switching for frequencies from CW up to 155 MHz.
When the laser driver is working, we will design a shield with all the needed controlling units on it.
We are planing to release an open exposer DIY kit next year.
Maker Faire Berlin
09/23/2015 at 07:35 • 0 commentsOf course i will bring the Open Exposer project to Berlins first Maker Faire on 3th and 4th of October. You can find this project at the booth of "Freie Maker".
First printing test with the flex vat
09/13/2015 at 19:55 • 0 commentsToday i had the time to test the Open Exposer flex vat. And i can proudly announce that it is working. With the flex vat there is no need for a vat tilt mechanism anymore. It it also much easier to clean the vat and change the vat foil. Thanks to @Moritz for his great vat design files!
It is time now to work on better print results. The first task is writing a new Slicer for the Open Exposer.
Replaced Petri dish/vat with FEP Flex vat
08/20/2015 at 14:57 • 0 commentsFirst of all, special thanks to @Moritz for sharing his Flex vat files. Last weekend i made a modification of the original fep-vat files which @Moritz provides at GitHub. Here are some pictures of my modification for the Open Exposer.
And finally here a short Youtube video where i tested the vat tension.
I will do a print test with the new FEP-Vat this weekend.
Chaos Communication Camp 2015
08/05/2015 at 08:44 • 0 commentsI will bring the Open Exposer project to the ccc camp.
Maker Faire Hannover 2015
06/10/2015 at 10:32 • 0 commentsThank you for visiting me at our booth. The Maker Faire in Hannover was a big success.
See you in at Maker Faire in Berlin.
Open Exposer at Maker Faire Hannover
06/08/2015 at 11:25 • 0 commentsLast weekend i presented the current version of Open Exposer at the Maker Faire in Hannover.
Bay Area Maker Faire 2015
05/06/2015 at 07:17 • 0 commentsHello all,
i am going to visit this years Bay Area Maker Faire. If anybody is there and wants to discuss/talk about projects and other cool stuff, write me an email (you'll find my email address by following some links here :) ) or tweet @l_k3.
I am also planing to have a beer at https://hackaday.io/event/5599-bay-area-maker-faire-after-party
See you there.
The first successful print test!
05/05/2015 at 20:52 • 0 commentsToday printed a small cube with open exposer. This is the first print which is higher than 1-2mm. I was able to reproduce the result.
Mario Lukas
