The bottom side is soldered. It was quite difficult to get the 0201 capacitors (the two next to the crystal) soldered correctly. The dimension of crystal is 2 x 1.6 mm.
Next Task is to solder the to side with its 64 RGB Leds. But I will not do that today. One side a day extreme soldering is enough. And then I hope it will also work.
Alex
nowone is scairdy cats
i dear someone ton toghch one!
whoa 0201s! Well done!!
impressive!
seconded! Thems some tiny capacitors!
Good job on placing those caps.
Thanks
