Lets set some initial requirements!
Hardware requirements
- Facilitate electrical connection to atari2600 game cartridge
- Push back the cartridges dust cover
- Supply 5V to the cartridge
- Communicate with cartridge using TTL compatible signal levels
- Communicate with software running on PC
- Access LED
Firmware requirements
The requirements for the firmware running on the microcontroller
- Communicate with software domain
- Read/write from/to any address in the atari2600's address space
- Control acces LED
Software requirements
The requirements for the software running on the PC
- Options
- Bankswitching method
- Output file path
- Communicate with firmware domain
- Save ROM image to file
- Launch emulator
