Arduino (Uno/Mega) MC14499 code
03/08/2015 at 11:33 • 0 commentsArduino Uno:
//MC14499 static int latchPin = 8; //enable static int clockPin = 12; //clock static int dataPin = 11; //data
Arduino Mega:
//MC14499 static int latchPin = A0; //enable static int clockPin = 49; //clock static int dataPin = 48; //data
Common:
void mc14499ShiftOut(byte val) { for (int i = 0; i < 4; i++) { digitalWrite(dataPin, !!(val & (1 << (3 - i)))); digitalWrite(clockPin, HIGH); digitalWrite(clockPin, LOW); } }
/* b1 => Green 7-segment "bus 1" b2 => Green 7-segment "bus 2" h1 => Orange 7-segment "hours 1" h2 => Orange 7-segment "hours 2" m1 => Orange 7-segment "minutes 1" m2 => Orange 7-segment "minutes 2" s1 => Orange 7-segment "seconds 1" s2 => Orange 7-segment "seconds 2" */ static void affi7(byte b1, byte b2, byte h1, byte h2, byte m1, byte m2, byte s1, byte s2) { digitalWrite(latchPin, LOW); mc14499ShiftOut(B00001111); mc14499ShiftOut(s2); mc14499ShiftOut(s1); mc14499ShiftOut(m2); mc14499ShiftOut(m1); mc14499ShiftOut(B00001111); mc14499ShiftOut(b2); mc14499ShiftOut(b1); mc14499ShiftOut(h1); mc14499ShiftOut(h2); digitalWrite(latchPin, HIGH); }
static void affi(int bus, int hours, int minutes, int seconds) { byte s2 = (byte)(seconds-(seconds/10)*10); byte s1 = (byte)(seconds/10); byte m2 = (byte)(minutes-(minutes/10)*10); byte m1 = (byte)(minutes/10); byte b2 = (byte)(bus-(bus/10)*10); byte b1 = (byte)(bus/10); byte h2 = (byte)(hours-(hours/10)*10); byte h1 = (byte)(hours/10); if (b1 == 0) b1 = 0xFF; if (hours == 0xFFFF) { h1 = 0xFF; h2 = 0xFF; if (minutes == 0xFFFF) { m1 = 0xFF; m2 = 0xFF; } } affi7(b1, b2, h1, h2, m1, m2, s1, s2); }
void setup() //arduino setup { pinMode(latchPin, OUTPUT); pinMode(clockPin, OUTPUT); pinMode(dataPin, OUTPUT); }
On the picture:void loop() { affi(2, 19, 50, 00); }
