Print it
05/27/2016 at 02:07 • 0 commentsOur first model.
Ladies and gentlemen, we present to you the first physical model of B-Pi.
We chose a 3D modeling, for its speed and easy handling, with this first prototype we know what we need remake the structure and needs to be a little bigger to have enough space for the electronic design.
Current measures of this model are 3x3 cm, in
Size of the device in a hand, It is small but needs to be bigger.
Whats Next?
- Make a second 3D model.
- Make the connection with the Android phone
- Make the first schematic
B-Care, B-Safe, B-Pi.
Our First Steps
05/26/2016 at 05:38 • 1 commentProgress
In a first rapid prototyping we use an Arduino UNO development as a tablet and a GPS module to detect the location.
The Arduino Uno is used only at this stage to facilitate the portability of the code, in a future model is replaced by a smaller microcontroller (ATmega)
The selected values are important in the first stage of design, showing the latitude, longitude, date and time, these values are important to provide adequate monitoring and uninterrupted.
Project status
At this stage of design and programming the device following the vessel we can grant the indicators:- Latitude 19.4126112
- Length -99.1107979
- Time 1132
- Date 260516
Whats Next?- A first 3D printed physical model to adjust measures components.
- Communication via Bluetooth with an Android OS device.
B care, B Safe, B-Pi.
Abraham Chavez
