ESP8266-12E Programming & Testing Adapter
simple adapter to program and test esp8266-12e using pogo pins for solderless connections
Made this adapter to program and test esp8266-12e modules. Since these modules would end up in my final build, I was looking for a solution that would let me program them without any soldering. Using pogo pins allows for simple connection without any soldering involved
Rich text editor
Chip Stewart wrote 03/10/2017 at 19:49 point
I'd like to try building this.  Could you send me the .brd or at least a schematic?
Ankit Bhatnagar wrote 03/11/2017 at 08:19 point
Unfortunately I lost those when I lost my hard disk. I only have the final artwork file which you can transfer to copper clad.
https://www.dropbox.com/s/icpfzz46x1534vl/drawing.svg?dl=0
sbi.gaijin wrote 06/17/2016 at 23:48 point
Neat idea!
Looks as though it might benefit from a (non-conductive) hold-down across the tops of the pogo-pins (or perhaps just a second, unconnected solder pad under the body of each pin) to prevent vertical stresses from ripping them up off the (end) solder pads.
sk1tt1sh wrote 06/17/2016 at 22:36 point
Any chance you'd share the eagle file and parts you used for this?
