simple adapter to program and test esp8266-12e using pogo pins for solderless connections
Unfortunately I lost those when I lost my hard disk. I only have the final artwork file which you can transfer to copper clad.
Neat idea!
Looks as though it might benefit from a (non-conductive) hold-down across the tops of the pogo-pins (or perhaps just a second, unconnected solder pad under the body of each pin) to prevent vertical stresses from ripping them up off the (end) solder pads.
Any chance you'd share the eagle file and parts you used for this?
I'd like to try building this. Could you send me the .brd or at least a schematic?
