1Step 1
These are the initial instructions for building the version 2.5 spectrometer, from these and with much pratical application and modifications the v2.5 (build 3.0.1) was born. -
2Step 2
This is the new proto type CMOS Camera module mount, for the DAV 5 UV/VIS Spectrometer which I am now starting to bring back to life. I designed the camera mount using FreeCad version 0.16 and sculpted a working model out of high density matte foam.
REV.1
3Step 3
This is my new Gillette razor blade open-air slit design; 0.12mm slit width. Verified using my Aries DPSS 150mW 532nm Green Laser through a quartz cuvette containing 99.99% purity Isopropyl alcohol (lab grade certified.)
4Step 4
5Step 5
6Step 6
7Step 7
This is draft number 1 for the DAV5 spectrometer that will house all the internal parts.
8Step 8
This is the camera mount for the ELP cmos camera for the DAV5 Spectrometer, I have built the prototype and will post the pics soon.
9Step 9
This is my prototype build for the ELP cmos camera for the new DAV5 spectrometer.
David H Haffner Sr
