I tested my spectrometer's resolution by chemically analyzing 2 crude oil samples from my previous tests and I am quite happy with the results, this means that my resolution is good and my signal to noise ratio is good.
A project log for DAV 4 UV/VIS Spectrometer
Well, this is the next evolutionary step from when I first bought the Plab 2.5 spectrometer kit
