- Define the expectations of the electronic door system and Brainstorm on all aspects of this project from a feature perspective.
- Classify lock system into sub project categories
- Determine if Feature Development Versions are needed
- If time permits, explore each category in more depth.
- Assign (if any) follow up work to be done by participants for next meeting.
- At all possible, keep this entire project open source and documented to be shared with other hackerspaces upon completion.
Initial Thoughts:
- Secured Access featuring 2 Factor Authentication (text, fingerprint, keypad,NFC,RFID?)
- Manual override (landlord, power outage,etc.)
- Remote override
- Database Query for entry validation
- Temporary and single use passwords
- Logging User Entry
Notes from after meeting:
- Power System ?
- Power on reboot for system & database network
- Multiple login attempt monitoring.
- Delay each attempt +5 seconds
- Lockout after X attempts
- Photo capture each failed attempt.
- Notify board members upon certain attempt threshold.
- Remote Override Management & Security.
