JPEG Image -
2.09 MB -
07/31/2022 at 18:18
Preview
JPEG Image -
1.90 MB -
07/31/2022 at 18:18
Preview
JPEG Image -
2.16 MB -
07/31/2022 at 18:18
Preview
JPEG Image -
1.66 MB -
07/31/2022 at 18:18
Preview
5mm_LED_holder v3.stl
Standard Tesselated Geometry -
29.57 kB -
12/13/2018 at 21:38
Download
18_tooth_gear v3.stl
677.43 kB -
12/12/2018 at 14:39
Download
12_tooth_gear v3.stl
603.01 kB -
12/12/2018 at 14:39
Download
Camera_mount_8mp_bottom v3.stl
235.63 kB -
12/12/2018 at 14:39
Download
Platform v3 .stl
89.14 kB -
12/12/2018 at 14:39
Download
Optical_tube v3.stl
238.27 kB -
12/12/2018 at 14:39
Download
Geared_rack v3.stl
54.57 kB -
12/12/2018 at 14:39
Download
Tubeholder v3.stl
112.19 kB -
12/12/2018 at 14:39
Download
Camera_mount_8mp_top v3.stl
84.85 kB -
12/12/2018 at 14:39
Download
Refined pi camera adapter v7.f3d
fusion -
110.68 kB -
07/10/2016 at 23:05
Download
platform v6.f3d
fusion -
123.80 kB -
07/10/2016 at 23:05
Download
Adjustment mount v5.f3d
fusion -
109.36 kB -
07/10/2016 at 23:05
Download
Ring v1.f3d
fusion -
30.63 kB -
07/10/2016 at 23:05
Download
Knob v4.f3d
fusion -
130.67 kB -
07/10/2016 at 23:05
Download
base spar holder v5.f3d
fusion -
96.68 kB -
07/10/2016 at 23:05
Download
Motor mount v4.f3d
fusion -
115.95 kB -
07/10/2016 at 23:05
Download
160mm tube v6.f3d
fusion -
44.87 kB -
07/10/2016 at 23:05
Download
Base Spar holder.stl
149.69 kB -
07/10/2016 at 01:25
Download
Motor mount.stl
83.09 kB -
07/10/2016 at 01:25
Download
Top plate laser guide.dxf
AutoCAD DXF -
6.74 kB -
07/10/2016 at 01:25
Download
Slide Platform.stl
Also print solid, standard metal spring loaded slide holders fit well.
79.38 kB -
06/27/2016 at 20:32
Download
big gear 30 teeth.stl
Nice and big gear
915.11 kB -
06/27/2016 at 20:27
Download
small gear 10 teeth.stl
Has a small hole so you can drill out to fit your motor type
274.52 kB -
06/27/2016 at 20:27
Download
Refined camera mount bottom.stl
Optical element, print in black
236.70 kB -
06/27/2016 at 20:27
Download
Refined camera mount top.stl
86.41 kB -
06/27/2016 at 20:27
Download
160mm Tube part A.stl
The optical tube, print in black
267.66 kB -
06/27/2016 at 20:27
Download
Focus ring.stl
Where you tie the high test fishing line too.
80.84 kB -
06/27/2016 at 20:27
Download
Fancy knob.stl
It is a human to machine interaction device
246.57 kB -
06/27/2016 at 20:27
Download
Focus Mount.stl
It holds it all together and has holes that bearings fit into.
141.00 kB -
06/27/2016 at 20:27
Download
Focus axle.stl
A simple axle, print solid
79.87 kB -
06/27/2016 at 20:27
Download
160mm Tube part B.stl
147.54 kB -
06/27/2016 at 20:27
Download
Base plate.stl
This is a the fancy base that secures the scope and has holes to fill with rocks, ball bearings, or even crushed sea shells for weight.
17.27 kB -
06/27/2016 at 20:27
Download
motor_control.py
A updated control of the stepper for the Z axis with a added speed control variable
plain -
2.28 kB -
06/16/2016 at 22:47
Download
microscope base.stl
The fancy base
13.60 MB -
06/16/2016 at 22:41
Download
README.md
Basic information
md -
70.00 bytes -
04/29/2016 at 02:49
Download
