yo ho ho and three bottles of rum. we have problems with soldering. using weller 140/100 soldering guns, supposed to heat up and melt solder in 6 seconds. when the tips are fresh, this happens. later, the tips start to turn black, and it no longer works. this may be because we aren't leaving solder on the tips after the work is done. is this true? is there a reliable way of fixing a tip that has gone black? thanks! wiring is proceeding nicely, regularly replacing tips, but that is obviously not a good solution..
Buy solder-tip cleaner and tinning.
Blackened soldering iron tips are usually caused by running the iron too hot and the solder boiling off the more volatile components of the solder. Not good to solder using a black tip either.
Periodically clean the tip using a tip cleaner,(those bronze colored scrub pad looking things) then re-tin the tip(usually a white looking compound in a small round tin). Turn it off when it isn’t being used.
Weller soldering guns and stations are great, but everything needs maintenance.
