Thanks to Janice, here's a cool recipe for ultrasound gel.
I messed with the recipe awhile and came up with a very nice slightly caramel tinged ultrasound gel this way:
- Mix 2 teaspoons of guar gum with 1-2 teaspoons of salt. (The amount of salt isn't vitally important since it is just added to keep the guar gum from clumping. Using slightly less than a teaspoon of salt per 2 cups makes a gel with which is isotonic, which would be ideal for use near eyes or other mucus membranes or on open wounds).
- Boil two cups of water.
- Slowly sprinkle the guar gum/salt mixture into the boiling water while stirring vigorously with a fork or whisk.
- Boil for about 1-2 minutes until thick and well mixed.
- Cool before using. Save lives.
And the movie :
