So in order to achieve a synced and not distorted picture, the timing for one 3D frame has to be like the following table, instead of a factor of 0.125.
I probably end up measuring the time of 2 frames, when it retracts to the electronics side, so I have to keep that in mind.
And wow... I had to make a screenshot of the table because it looked really bad here on projects..
