Thumbs Up Bitmap Demo
05/01/2016 at 08:02 • 0 comments![]()
// Drawing a bitmap on scope by Hari Wiguna, 2016 // Playing with R-2R Ladder to convert Digital to Analog // We'll use PORTD because it gives us contiguous 8 bits // Thanks to digole.com for the bitmap to array converter: http://www.digole.com/tools/PicturetoC_Hex_converter.php const uint8_t xMax = 219; // # of columns const uint8_t yMax = 230; // # of rows const uint8_t bandMax = 28; // 219/8 rounded up// This is only some of the bytes of the bitmap. // See github for full listing.const unsigned char image[] PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f }; void setup() { DDRD = B11111111; // Set all bits of PORTD as output } void loop() { DrawBitmap(); } void DrawBitmap() { int horizUnit = 40; // how spaced out horizontally between x pixels? PORTD = 255; // Set to high so we could trigger consistently at this level for (uint8_t band = 0; band < bandMax; band++) // each band is a column of eight pixels { for (uint8_t x = 0; x < 8; x++) // draw 8 horizontal pixels per band { for (uint8_t y = 0; y < yMax; y++) // draw 230 rows of vertical pixels { uint8_t bitAnalogValue = 10+ y; // Offset from 0V so image would be vertically above the almost solid 0V line unsigned char vertByte = pgm_read_byte_near(image + ( (yMax-y) * bandMax + band)); // get the byte representing that row and band if ( ((band*8+x)<xMax) && bitRead(vertByte, 7-x)) PORTD = bitAnalogValue; else PORTD = 0; // if it's within bound and it's ON, move beam to that Y position delayMicroseconds(horizUnit); // Wait a little to allow scope to draw a short horizontal line. } } } PORTD = 0; delay(1000); // Set to 0V and wait before drawing again } -
Hello YouTube Demo
05/01/2016 at 04:39 • 0 comments![]()
// Drawing letters on scope by Hari Wiguna, 2016 // Playing with R-2R Ladder to convert Digital to Analog // We'll use PORTD because it gives us contiguous 8 bits // Font courtesy of: http://jared.geek.nz/2014/jan/custom-fonts-for-microcontrollers const uint8_t fontWidth = 8; const PROGMEM uint8_t font[] = { 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // 0x00,0x5f,0x00,0x00,0x00,0x00,0x00,0x00, // ! 0x00,0x03,0x00,0x03,0x00,0x00,0x00,0x00, // " 0x0a,0x1f,0x0a,0x1f,0x0a,0x00,0x00,0x00, // # 0x24,0x2a,0x2a,0x7f,0x2a,0x2a,0x12,0x00, // $ 0x00,0x47,0x25,0x17,0x08,0x74,0x52,0x71, // % 0x00,0x36,0x49,0x49,0x49,0x41,0x41,0x38, // & 0x00,0x03,0x00,0x00,0x00,0x00,0x00,0x00, // ' 0x00,0x3e,0x41,0x00,0x00,0x00,0x00,0x00, // ( 0x41,0x3e,0x00,0x00,0x00,0x00,0x00,0x00, // ) 0x04,0x15,0x0e,0x15,0x04,0x00,0x00,0x00, // * 0x08,0x08,0x3e,0x08,0x08,0x00,0x00,0x00, // + 0x00,0xc0,0x00,0x00,0x00,0x00,0x00,0x00, // , 0x08,0x08,0x08,0x08,0x08,0x00,0x00,0x00, // - 0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // . 0x40,0x20,0x10,0x08,0x04,0x02,0x01,0x00, // / 0x00,0x3e,0x61,0x51,0x49,0x45,0x43,0x3e, // 0 0x01,0x01,0x7e,0x00,0x00,0x00,0x00,0x00, // 1 0x00,0x71,0x49,0x49,0x49,0x49,0x49,0x46, // 2 0x41,0x49,0x49,0x49,0x49,0x49,0x36,0x00, // 3 0x00,0x0f,0x10,0x10,0x10,0x10,0x10,0x7f, // 4 0x00,0x4f,0x49,0x49,0x49,0x49,0x49,0x31, // 5 0x00,0x3e,0x49,0x49,0x49,0x49,0x49,0x30, // 6 0x01,0x01,0x01,0x01,0x01,0x01,0x7e,0x00, // 7 0x00,0x36,0x49,0x49,0x49,0x49,0x49,0x36, // 8 0x00,0x06,0x49,0x49,0x49,0x49,0x49,0x3e, // 9 0x14,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // : 0x40,0x34,0x00,0x00,0x00,0x00,0x00,0x00, // ; 0x08,0x14,0x22,0x00,0x00,0x00,0x00,0x00, // < 0x14,0x14,0x14,0x14,0x14,0x00,0x00,0x00, // = 0x22,0x14,0x08,0x00,0x00,0x00,0x00,0x00, // > 0x00,0x06,0x01,0x01,0x59,0x09,0x09,0x06, // ? 0x00,0x3e,0x41,0x5d,0x55,0x5d,0x51,0x5e, // @ 0x00,0x7e,0x01,0x09,0x09,0x09,0x09,0x7e, // A 0x00,0x7f,0x41,0x49,0x49,0x49,0x49,0x36, // B 0x00,0x3e,0x41,0x41,0x41,0x41,0x41,0x22, // C 0x00,0x7f,0x41,0x41,0x41,0x41,0x41,0x3e, // D 0x00,0x3e,0x49,0x49,0x49,0x49,0x49,0x41, // E 0x00,0x7e,0x09,0x09,0x09,0x09,0x09,0x01, // F 0x00,0x3e,0x41,0x49,0x49,0x49,0x49,0x79, // G 0x00,0x7f,0x08,0x08,0x08,0x08,0x08,0x7f, // H 0x00,0x7f,0x00,0x00,0x00,0x00,0x00,0x00, // I 0x00,0x38,0x40,0x40,0x41,0x41,0x41,0x3f, // J 0x00,0x7f,0x08,0x08,0x08,0x0c,0x0a,0x71, // K 0x00,0x3f,0x40,0x40,0x40,0x40,0x40,0x40, // L 0x00,0x7e,0x01,0x01,0x7e,0x01,0x01,0x7e, // M 0x00,0x7e,0x01,0x01,0x3e,0x40,0x40,0x3f, // N 0x00,0x3e,0x41,0x41,0x41,0x41,0x41,0x3e, // O 0x00,0x7e,0x09,0x09,0x09,0x09,0x09,0x06, // P 0x00,0x3e,0x41,0x41,0x71,0x51,0x51,0x7e, // Q 0x00,0x7e,0x01,0x31,0x49,0x49,0x49,0x46, // R 0x00,0x46,0x49,0x49,0x49,0x49,0x49,0x31, // S 0x01,0x01,0x01,0x7f,0x01,0x01,0x01,0x00, // T 0x00,0x3f,0x40,0x40,0x40,0x40,0x40,0x3f, // U 0x00,0x0f,0x10,0x20,0x40,0x20,0x10,0x0f, // V 0x00,0x3f,0x40,0x40,0x3f,0x40,0x40,0x3f, // W 0x00,0x63,0x14,0x08,0x08,0x08,0x14,0x63, // X 0x00,0x07,0x08,0x08,0x78,0x08,0x08,0x07, // Y 0x00,0x71,0x49,0x49,0x49,0x49,0x49,0x47, // Z 0x00,0x7f,0x41,0x00,0x00,0x00,0x00,0x00, // [ 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // "\" 0x41,0x7f,0x00,0x00,0x00,0x00,0x00,0x00, // ] 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // ^ 0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x00, // _ 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // ` 0x00,0x7e,0x01,0x09,0x09,0x09,0x09,0x7e, // A 0x00,0x7f,0x41,0x49,0x49,0x49,0x49,0x36, // B 0x00,0x3e,0x41,0x41,0x41,0x41,0x41,0x22, // C 0x00,0x7f,0x41,0x41,0x41,0x41,0x41,0x3e, // D 0x00,0x3e,0x49,0x49,0x49,0x49,0x49,0x41, // E 0x00,0x7e,0x09,0x09,0x09,0x09,0x09,0x01, // F 0x00,0x3e,0x41,0x49,0x49,0x49,0x49,0x79, // G 0x00,0x7f,0x08,0x08,0x08,0x08,0x08,0x7f, // H 0x00,0x7f,0x00,0x00,0x00,0x00,0x00,0x00, // I 0x00,0x38,0x40,0x40,0x41,0x41,0x41,0x3f, // J 0x00,0x7f,0x08,0x08,0x08,0x0c,0x0a,0x71, // K 0x00,0x3f,0x40,0x40,0x40,0x40,0x40,0x40, // L 0x00,0x7e,0x01,0x01,0x7e,0x01,0x01,0x7e, // M 0x00,0x7e,0x01,0x01,0x3e,0x40,0x40,0x3f, // N 0x00,0x3e,0x41,0x41,0x41,0x41,0x41,0x3e, // O 0x00,0x7e,0x09,0x09,0x09,0x09,0x09,0x06, // P 0x00,0x3e,0x41,0x41,0x71,0x51,0x51,0x7e, // Q 0x00,0x7e,0x01,0x31,0x49,0x49,0x49,0x46, // R 0x00,0x46,0x49,0x49,0x49,0x49,0x49,0x31, // S 0x01,0x01,0x01,0x7f,0x01,0x01,0x01,0x00, // T 0x00,0x3f,0x40,0x40,0x40,0x40,0x40,0x3f, // U 0x00,0x0f,0x10,0x20,0x40,0x20,0x10,0x0f, // V 0x00,0x3f,0x40,0x40,0x3f,0x40,0x40,0x3f, // W 0x00,0x63,0x14,0x08,0x08,0x08,0x14,0x63, // X 0x00,0x07,0x08,0x08,0x78,0x08,0x08,0x07, // Y 0x00,0x71,0x49,0x49,0x49,0x49,0x49,0x47, // Z 0x08,0x36,0x41,0x00,0x00,0x00,0x00,0x00, // { 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // | 0x41,0x36,0x08,0x00,0x00,0x00,0x00,0x00, // } 0x02,0x01,0x01,0x02,0x02,0x01,0x00,0x00, // ~ 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00 }; char topWord[] = " HELLO "; char bottomWord[] = "YouTube"; void setup() { DDRD = B11111111; // Set all bits of PORTD as output } void loop() { MultiChar(); } void MultiChar() { int horizUnit = 90; PORTD = 250; for (uint8_t i = 0; i < sizeof(topWord) - 1; i++) { for (uint8_t x = 0; x < fontWidth; x++) { for (uint8_t r = 0; r < 2; r++) { int ch = ((r == 0) ? bottomWord[i] : topWord[i]) - ' '; uint8_t rowOffset = 80 * r; uint8_t bitAnalogValue = 40 + rowOffset; unsigned char vertByte = pgm_read_byte_near(font + ch*8 + x); for (uint8_t y = 0; y <= 7; y++) { bitAnalogValue += 7; if (bitRead(vertByte, 7 - y)) PORTD = bitAnalogValue;// else PORTD = 0; delayMicroseconds(horizUnit); } } } PORTD = 0; delayMicroseconds(500); } delay(20); }
