This Button was created for a Project for my son. Each time you touch the front of the button or tap against it, you will get an impils of 1sec. You can change the length of the impuls, by changing the capacitor and the resistor of the timer cirquit. It is also a solution to use these buttons for older peoples or for People with disabilities.
Alain Mauer
Tillo
Martin W. Kirst
Sven Hecht
brilliant!
