The particle events fired are called button1 to button4 with the values of D0 to D4. If you just want to check for buttons pressed, just forget the values.
Requests
set_relay switches on and off the relay (0 is off, everything else is on).
set_colour sets the RGB LED to the colour given as hex (for example ff0000 or #ff0000 for red)
Tillo
GeoNomad
Alain Mauer
Owl Labs
Abhishek Ghosh
