Treecam is back online!
06/16/2016 at 02:46 • 0 commentsthe treecam can now be found at http://208.74.177.3:8081/
High exposure
06/08/2016 at 18:44 • 0 commentsIt seems that the Logitech 920 will shutdown in periods of high exposure in the morning. Once shutdown, the power to the raspberry Pi must be reset. A reboot from within eye os does not work. I would like to add a relay to the camera usb port and control it from eye os or even with a remote command from ispy.
Still going strong offline
06/01/2016 at 23:49 • 0 commentsWell the treecam is still running strong. I cannot currently connect it to the internet, because the device i am using as a router does not forward ports properly.
Internet down
05/11/2016 at 20:03 • 0 commentsMy connection to the Internet is currently down, and the tree cam is offline temporarily. All will be reestablished soon...
