Endplate_B.pdf
This endplate was modified to allow us to mount the VGA output from the SBC and to have some USB ports.
Adobe Portable Document Format -
31.17 kB -
10/10/2016 at 06:03
Preview
Endplate_A.pdf
This is a drawing of one of the endplates for the chassis. It doesn't need modification
73.02 kB -
10/10/2016 at 05:56
Preview
Chassis.pdf
This is the original drawing of the chassis before we modified it to lighten it. Feel free to print it in light weight plastic!
120.39 kB -
10/10/2016 at 05:56
Preview
Lid.pdf
This is the original drawing for the lid before we modify it for the SBC.
84.02 kB -
10/10/2016 at 05:56
Preview
Bakman_THz_Review.pdf
This pdf is an overview of how a THz photomixing system works. It explains coherent detection and how two semiconductor lasers and two semiconductor mixers can be used to generate and detect THz radiation.
1.09 MB -
06/15/2016 at 19:16
Preview
Drone Adapter Plate - Cropped.pdf
Two of these plates will be used to attach the PB7220 to the DJI-S1000. We will fabricate them from aluminum.
84.63 kB -
05/29/2016 at 20:49
Preview
Chassis_edit.pdf
The chassis was modified to reduce weight. Sections that weren't required were removed as per the drawing.
173.67 kB -
05/28/2016 at 21:52
Preview
JoeDemersPart1.PDF
A square hole for the SBC heatsink was cut into the lid and mounting holes were added.
18.71 kB -
05/28/2016 at 21:49
Preview
