Little Maker Assembly Plant
The future generation, "Little Makers," can use "hands on" assembly toys to fuel imagination.
Recently, I "worked" on a side loading garbage truck for 8 hours with a 3 year old child. I wore a blister on my "crank the can into place" finger before he caught on--but he did catch on. I see a need for interactive toys where the kid (not the toy) does the work.
When Woz (inventor of the Apple computer) was less than four years old, his father was showing him things. Woz thought, "Wow. For people who know how to do this stuff--how to take these little parts and make them work together to do something--well, these people must be the smartest people in the world." Kids need exposure to more than video images, exposure to real things.
This project provides an assembly line (the belt is powered by a hand crank generator). Bins or hoppers (with release levers) and chutes drop parts onto the belt.
The legs, arms and heads of the provided "little person" come in different colors and shapes, many outputs are possible.
The project is starting to come together--here's a functioning line.
Going forward I hope to create:
More Modules
More Toys to Assemble
Method to Link Conveyor Belts
Now there is a rotating parts module in the first assembly position.
Here is a video of a super preliminary prototype.
As a complete system,  conveyor belts will be controlled by switches and powered by a hand crank generator. Supply bins will be manual or electric--electric being powered by the hand crank generator through switches. Supply bins will be modular and changeable. Similar to the old Lionel trains, the switches and modules can be wired by the user (kids) and they will learn about wiring and polarity.
The first prototype makes use of a "Hackaday Bot" that can be found at Thingiverse.
The entire assembly can be placed on a play table.
belt motor bearing.stl
Standard Tesselated Geometry - 334.83 kB - 04/20/2018 at 18:55
Download
belt spool motor.stl
Standard Tesselated Geometry - 1.77 MB - 04/20/2018 at 18:55
Download
belt spool.stl
Standard Tesselated Geometry - 1.42 MB - 04/20/2018 at 18:55
Download
motor holder.stl
Standard Tesselated Geometry - 524.35 kB - 04/20/2018 at 18:55
Download
bearing supporta.stl
Standard Tesselated Geometry - 295.84 kB - 04/20/2018 at 18:55
Download
View all 63 files
  • Conveyor Belt
    Mike Rigsby04/20/2018 at 19:04 0 comments
    Print (3) bearing supports and install 6x19x6 mm bearings.
    Print one "belt spool motor" and one "belt motor bearing." Glue or melt the "belt motor bearing" to the end of the "belt spool motor."
    Print one "belt spool" and two "belt motor bearing" pieces. Glue or melt the "belt motor bearing" pieces to the ends of the "belt spool." Wrap the belt around the spools, then place the shaft ends into the "bearing supports." Place the motor in the "motor holder" (secure with 3mm screws). Adjust the bearing supports until the belt is in reasonable tension, then secure to the plywood base using wood screws.
  • Generator
    Mike Rigsby04/20/2018 at 17:16 0 comments
    In this step I create a hand crank generator to power the conveyor belt.  Let's start with a MG995 servo motor.
    Remove the screws and the back plate.
    Cut the three wires (under the circuit board) that lead to the potentiometer.
    Remove the potentiometer--it is one of two items that prevent full rotation of the gears.
    Open the gear cover. On the large brass gear, there is a pin protruding. Lift that pin out (it should remove easily).
    Remove the circuit board by cutting the two red wires that lead to the motor.
    Solder connecting wires from the motor (about 10 inches long).
    Close the motor and screw everything back together.
    Fasten the crank to the servo horn, then secure the motor in the servo mounting bracket. Attach the crank to the servo motor shaft.
    Screw a terminal block to the plywood base. This block will allow little makers to move the wires around if they elect to mess with them.
    Connect the wires from the servo motor (generator) to the motor. The belt should move when you turn the generator. Switch the red and black wire positions if the direction of cranking does not match the movement of the belt.
  • Robot People
    Mike Rigsby04/20/2018 at 13:35 0 comments
    We need something to assemble on the line, so I came up with "robot" people. There are two leg styles, two arm styles, two body styles, three head styles and a cup to fit one of the arms.
    The 3d print files are available on this site. The legs, arms and head screw into the body (legs must go in before the arms). My favorite is Mike's head (my head). Using a 3d sense scanner on a tripod, I slowly turned around in a low back office chair and scanned my head.
    The other heads came from elves in Santa's Shop.  If the parts are printed in different colors, even more variations can be produced.
  • Hopper Module
    Mike Rigsby04/19/2018 at 21:09 0 comments
    In this module, I fill the hopper with robot heads. Pulling down on the release lever (held up by rubber bands) allows a head to come out for the assembly process.
    Insert the hopper release bolt through the hopper chute and hopper release.
    Add the nut to the end of the release bolt.
    Insert rubber bands through the hooks at the top of the hopper.
    Place the other end of the rubber band around the hopper release. Attach the hopper thread base to the hopper chute with nuts and bolts.
    Thread this into place on the main board, fill it with parts and you are ready to dispense!
  • Tray Push Module
    Mike Rigsby04/19/2018 at 18:40 0 comments
    In this log, I show how to make the "Tray Push Module." This module screws onto the "bin base." When the tray is filled with robot bodies, the pusher at the rear of the module can be pulled back and pushed forward to release a new body in the front landing tray.
    Print the tray tower.
    Attach the tower to the tray base. I melt them together using a soldering iron.
    Screw this to a "bin base," insert the pusher in the rear slot and you are ready to load the tray with robot bodies (another log--coming soon!).
  • Turntable Module
    Mike Rigsby04/10/2018 at 21:22 0 comments
    Here I'll build a module that can be rotated by hand and easily attached or removed from the conveyor belt assembly.
    Start by attaching the bin base to the conveyor belt board using four #6 x 3/4 inch wood screws.
    Next, print the "bearing bottom" piece.
    Insert the bearing.
    Add the bearing top to the bearing assembly. The top piece has no screw threads in the outer holes.
    Secure the assembly by screwing the two bolts into the end holes.
    Print the bin spin combo and bring it to the bearing assembly.
    Press the "bin spin combo" into the bearing assembly.
    Bring the "gear lock" to this assembly and screw it into the bottom of the "bin spin combo."
    Attach the "module attach" piece to the above combo. I melt them together using a soldering iron, though I suppose they could be glued.
    The completed module, from the top, looks like this.
    The module can be easily screwed onto or off of the conveyor belt base.
  • Building the Hackaday Bot
    Mike Rigsby04/04/2018 at 21:10 0 comments
    This bot was quickly put together as a prototype toy for the assembly line.
    I used wire wrap wire to extend the led legs to the battery. Aluminum duct tape was used to secure the wires to the battery.
    Now, for the 3d part printing details.
    The head should be scaled to 40% of original size.
    The mid body should be scaled to 115% of original size.
    The legs should be scaled to 110% of original size.
View all 7 project logs
