Hackaday.io Hackaday.io
Sign up Log in
Various Micropython Libraries and Drivers
A collection of miscellaneous libraries and drivers for Micropython
dehipudeʃhipu
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
14.8k views
0 comments
40 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 19
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
14.8k
0
40
27
Team (1)
  • dehipudeʃhipu
Join this project's team
Software
ongoing project
micropython ESP8266 python library Driver
This project was created on 05/10/2016 and last updated 9 years ago.
Description
I'm collecting the various Micropython libraries (and drivers for various sensors and other devices) that I'm writing here. Some of them are specific to the ESP8266 port, some are general.
Project Logs
Collapse
  • OLED Displays
    deʃhipu • 10/17/2017 at 00:01 • 0 comments
    The code is at https://bitbucket.org/thesheep/micropython-oled/overview
    See the README for explanation and examples.
    This time I wrote drivers for something that mostly already had its drivers in MicroPython — the monochrome OLED displays. I did that, because I wasn't happy with the existing drivers — they are a bit elaborate in terms of indirection and inheritance. Sure, code reuse and so on, but not very nice for constrained platforms. So I did my own, trying to optimize them. I also exposed some useful functions, like flipping and hardware scrolling.
    I will hopefully add some more exotic displays there, as I get specimen to test on.
  • MAX31855 Thermocouple Amplifier
    deʃhipu • 02/08/2017 at 23:45 • 0 comments
    The code is at https://bitbucket.org/thesheep/micropython-max31855
    See the docstrings for usage.
  • SI7021 Temperature and Humidity Sensor
    The code is at https://bitbucket.org/thesheep/micropython-si7021
  • Bosch BNO055 IMU sensor
    deʃhipu • 02/08/2017 at 23:44 • 0 comments
    The code is at https://bitbucket.org/thesheep/micropython-bno055
    See the docstrings for usage example.
  • SHARP GP2Y0E03 Distance Sensor
    deʃhipu • 09/09/2016 at 13:29 • 0 comments
    This is a small infra-red distance sensor with I²C interface. It can measure distances from 4 to 127cm. The source code is available here: https://bitbucket.org/thesheep/micropython-gp2y0e03/src
    Example use:
    from machine import I2C, Pin
    import gp2y0e03
    i2c = I2C(Pin(5), Pin(4), freq=100000)
    s = gp2y0e03.GP2Y0E03(i2c)
    s.read()
  • µDisplay -- Drivers for 6 Different RGB Displays
    deʃhipu • 08/28/2016 at 17:51 • 1 comment
    This is a collection of 6 different displays drivers for TFT and OLED RGB displays. I finally took the time to refactor all my drivers, pull out the common parts, and put them all in a single library. Don't worry, each driver is in a separate file, so you can copy only the parts that you are actually using onto your board.
    The source is at https://bitbucket.org/thesheep/micropython-display
  • DS1307, DS3231, and PCF8523 Real-Time Clocks
    deʃhipu • 08/17/2016 at 14:50 • 0 comments
    Here's a library for handling a bunch of popular I2C-based real-time clock chips: https://github.com/adafruit/Adafruit-uRTC
    And here is the documentation for it: http://micropython-urtc.readthedocs.io/en/latest/
    As you can guess from the naming, I was supported by Adafruit Industries to write this one (but of course it will work with any breakout boards for those chips, not just theirs). I will most likely create more libraries for them.
  • SH1106 OLED Display
    deʃhipu • 07/15/2016 at 13:53 • 0 comments
    Another basic display driver. This one uses the framebuf module, as does the SSD1306 driver in Micropython's source tree.
    https://bitbucket.org/thesheep/micropython-ili9341/src/tip/sh1106.py
    The use is pretty much the same.
  • IS31FL3731 Charlie-Plexed LED Matrix
    deʃhipu • 07/09/2016 at 12:36 • 0 comments
    This driver is for a monochromatic matrix of up to 144 LEDs, with hardware PWM and blinking. It also has 8 frames of memory, and can fade between them, or play animations with them -- optionally synchronized to music! The code is at https://bitbucket.org/thesheep/micropython-is31fl3731/src/tip/is31fl3731.py
    Example use:
    import is31fl3731
    i2c = I2C(Pin(5), Pin(4))
    display = is31fl3731.CharlieWing(i2c)
    display.fill(127)
    display.pixel(0, 0, 2, True)
    display.blink(540)
  • SSD1606 E-ink display
    deʃhipu • 07/01/2016 at 13:43 • 5 comments
    This is a relatively cheap SPI E-ink display that you can find on tindie. It has 4 shades of grey per pixel, and 172x72 resolution.
    The code is at https://bitbucket.org/thesheep/micropython-ili9341/src/tip/ssd1606.py
    Example code:
    from machine import Pin, SPI
    import ssd1606
    spi = SPI(miso=Pin(12), mosi=Pin(13, Pin.OUT), sck=Pin(14, Pin.OUT))
    display = ssd1606.SSD1606(172, 72, spi, Pin(4), Pin(5), Pin(2), Pin(15))
    display.fill(3)
    display.pixel(10, 10, 0)
    display.show()
    And the display:
View all 19 project logs
Log In/Sign up to comment
Sign up with Github
OR
a simple project with dsPIC33
Project Owner Contributor
dsPIC: from Blink to QEI
jakub-pnkJakub P̵̗̋n̵̻̾k̶͙͘
A guy gave me this display back in college about 10 years ago. I finally got around to it.
VFD Shenanigans
gabrielGabriel
A 160x80 color LCD display that goes on top of the Trinket
Trinket M0 TFT
dehipudeʃhipu
The 2016 Hackaday Prize
motorcycle made smart with Atmega, hall effect sensor and OLED
SMARTDAX
tedTed
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Various Micropython Libraries and Drivers", please tell us the reason.
Send message
Remove Member
