This driver is for a monochromatic matrix of up to 144 LEDs, with hardware PWM and blinking. It also has 8 frames of memory, and can fade between them, or play animations with them -- optionally synchronized to music! The code is at https://bitbucket.org/thesheep/micropython-is31fl3731/src/tip/is31fl3731.py
Example use:
import is31fl3731
from machine import I2C, Pin
i2c = I2C(Pin(5), Pin(4))
display = is31fl3731.CharlieWing(i2c)
display.fill(127)
display.pixel(0, 0, 2, True)
display.blink(540)
deʃhipu
