This chip is actually used in two different modules. First it's used in the 16-channel I²C servo (and LED) drivers. Second, it's also used in Adafruit's motor shield. That's why apart from the main module, which lets you control the chip directly, there are also two others, specifically for the servos and the DC motors.
The source code is at https://bitbucket.org/thesheep/micropython-pca9685/src
deʃhipu
