1Step 1
The idea is the system should just require a Laptop and a simple, low tech, low cost pointer.
The application code is at https://github.com/jonkster/airpencil
The code is very rough - a quick hack to see if the idea has legs.
The pointer is also very rough - a yellow LED, switch and battery holder, zip tied to a wooden stick.
