Bad screen
05/18/2016 at 06:04 • 0 commentsI solder the components but screen doesn’t work (I just got sound).
After inspection of youtube video, it seems my screen is not the same.I’ve initially ordered that one : http://www.ebay.com/itm/201428440360 with PINs : GND, VCC, SCL, SDA where, on video, you can see : VCC, GND, SCL, SDA.
I’ve ordered new screens : http://www.ebay.com/itm/141987164192 to change them.
PCB built : errata
05/15/2016 at 16:26 • 0 commentsThe previous PCB was the first version.
A second version is available and makes it easier.
It is available here : http://webboggles.com/attiny85-game-kit-assembly-instructions/So I started again with that version.
PCB built
05/15/2016 at 10:43 • 0 commentsI just built the PCB using the toner + iron technique with some minor tracks problems.
I’ll try to fix them with the soldering iron.
