This is my candidate for a new standard for the MCU module. A 5V pin was added to the right connections, which are plugged to the main bus. The upper and lower connections were rearranged, organising the pins in groups per function and making it easier to change the ATMega328P MCU for another one, while keeping the connection standard to the submodules. This module is one pin larger than the last one. Please comment.
E. N. Hering
