This PS schematic is better. It includes the control lines PG, STAT1 and STAT2 on the submodule connections. This PS is also a LiPo charger. It should be able to switch seamlessly between output power (VIN) and battery power (VBAT), charging the battery when VIN is present.
E. N. Hering
