Hi again!
Following instructions from these links:
http://osdir.com/ml/cad.kicad.user/2007-12/msg00065.html
https://forum.kicad.info/t/the-file-append-board-menu-item-is-disabled/874/5
I made the following test panel, which will cost around 200 USD to be produced when 30 copies are ordered. The quote is from PCBWay.
E. N. Hering
Hi loldavid6! There will be plenty to spare. I'll let you know as soon as I check everything and place the order.
So, about $7 per panel? That's pretty good, i'd be interested in getting one if there are any going spare?
