Hi. My daughter is almost five months old and I just had some time to breath. I'm going to place an order on PCBWay to produce 30 panels similar to the one below. It has 2 servo control modules, two 9dof sensor modules, two power supplies, eight micro controller modules and a backbone to join all these. No components added.
The price for thirty panels is around 300 dollars, with delivery to Brazil. If you want to receive one of those panels, please tell me. I'll share the cost of the panel, shipping and import taxes (China-> Brazil) proportionally, add the shipping to you and send it. I will also gladly accept few dollars donations via PayPal to help cover those costs (enhering@gmail.com).
The price quote from PCBWay follows below. I do not know if exists a PCB manufacturer which works with project numbers, permitting anybody to order a panel independently, using only that number. Something like that would reduce the final costs of the panels.
Here is the quote from PCBWay:
I assume you understand that this panel includes *prototypes* of the last version of the system, and that there may be problems with it. I'll use them to assemble, debug and test the flight controller. I'll be very happy to help if you want to risk some money, assemble your own boards and help testing the system.
As always, your comments are welcome and very appreciated.
E. N. Hering
