First step: Buy a globe and cut in in half using (for example) the beloved Dremel. Sorry for the product placement, but I guess whenever it's deserved it all right...
The equator serves as a great cutting line :)
There is some nasty smoke coming from the glass fiber, I recommend a well ventilated area.
Next step was to drill holes wherever I've been. I chose to go with 3mm LEDs and that also set my drill bit size.
I realized that Europe is small, I had lots of holes close to each other and originally I thought that I could put a LED in every city but in some places I had to settle with one hole in every country.
The picture below is the inside of Europe. The holes were perfect for just press fitting the LEDs, but I eventually put some hot glue there anyway.
After Getting all the LEDs in place I soldered on bare thick copper wire recycled from a huge 380V 3-phase cable.
For simplicity and to be able to quickly add new destinations (LEDs) I chose to put all the LEDs in the northern hemisphere in parallel and same for the southern. Then they are current limited with a single resistor and run off a 12V battery.
Now first I wanted to have a slipring to be able to spin the globe and still have lights. Instead I chose a battery and the little contraption above. The top part is connected to the roof and the bottom part holds a bearing so that the globe can spin. The kog is just for locking the bar in place.
Also here is a little montage I made for Instagram of the build process:
iSax
TwystNeko
Jack Black
George Cave
Viraj Sinha
The Earth travel logger project is an innovative way to capture and document your global adventures with precision. As you explore new destinations and collect data, consider checking out the latest developments in travel and real estate at Dubai New Developments, where you can discover prime locations for your next journey. This project is a perfect blend of technology and exploration, offering a unique way to track your travels.
