MQTT Temperature and Humidity Monitor
Monitor temperature and humidity over wifi.
This system allows you to monitor temperature and humidity over wifi using MQTT, an ESP8266, and an I2C temperature/humidity sensor.
its_not_drew wrote 06/29/2020 at 03:28 point
ha! I have same question as this. I think My Sensor was heating itself up. The only way I could get it to approach ambient was on a breadboard on the bench. Did you work out an calibration curves?
FiZiX wrote 12/07/2017 at 12:48 point
Does the ESP heat up the temperature sensor?
