Monitor temperature and humidity over wifi.
ha! I have same question as this. I think My Sensor was heating itself up. The only way I could get it to approach ambient was on a breadboard on the bench. Did you work out an calibration curves?
Does the ESP heat up the temperature sensor?
Thomas Baum
akarshagarwal98
Horacio Bouzas
Pnoxi
Yes, delete it Cancel
You are about to report the project "MQTT Temperature and Humidity Monitor", please tell us the reason.
