Its been some time since I added a new log. I have been mulling over how to bring this all together. At first I thought this phase might be a new project. But I think it can be incorporated nicely to Clouds Happen. I will be sending the Sensor Tag motion data to IBM Bluemix Cloud .
Sending Sensor Data to IBM Bluemix
I used this excellent video by Ryan Baxter exclusively to achieve the deployment of sensor motion data to Bluemix The video was made in Nov 12, 2014 and Bluemix has changed. His video can be found here: . He was using a Beaglebone Black as a gateway and I am using a Raspberry Pi B. I had to make some modification to his code to accommodate the changes to Bluemix which I have documented. The screenshots in the video have changed so if you do follow the video than you may have to improvise to get where you need to be. Basically all you are doing is connecting a device and than creating a service. Then you can create a APP. You also need to sign up for a free trial from IBM. If I missed a step please let me know
At your terminal (I'm using Putty) use Git command to clone the repository . Found here - https://github.com/IBM-Bluemix/iot-sensor-tag.
git clone https://github.com/IBM-Bluemix/iot-sensor-tag
Move to the publish directory and execute the command npm install – You may see some warnings but as long as they are not errors it should be okay.
Now lets set up our Raspberry Pi in Bluemix ;
Console for IBM. Click on Catalog.
Select Internet of Things on the left. Now select Internet of Things
Under Connect you device – click on Launch dashboard
Select Create Device Type
Select Create device type:
Name your Device. Add the MAC address for the Pi. The MAC address can be found using ifconfig. All other fields are not mandatory
Generate you credentials . This is where I had to modify the code. During the setup you have to create a config.properties to store you credentials generated by Bluemix. This screen shot shows what I copied from Bluemix to Notepad. I changed the field names to match his code. My credentials have changed so I'm not concerned about showing them. The device.cfg shows one set of credentials modified to work in the program. If you view his video the syntax has changed to the example in Notepad. Use sudo nano within the publish directory to copy your credentials to that was generated by Bluemix.
Now we can start the program from the publish directory.
Node sensor-tag.js
Make sure your sensor tag is connected and you should see this in Putty.
Lets go back to Bluemix. Connected to fox tracker
Sensor data coming in !
I have created an app for the Fox Tracker .
Click on view App. I also imported a node red flow from the git repository.
