Still alive
06/28/2016 at 18:05 • 0 commentsI was very busy on my main job for a last few weeks, but project still alive and going on!
In race for smaller size, lower power consumption and what I found at local market, I failed in my idea with easy replicable design, because accelerometer manufactured in LGA16 package, that a little tricky for soldering.
Now work in progress:
- pcb design
- firmware for MCU
Anything Goes
05/29/2016 at 20:01 • 0 commentsThis were very busy weekend, but I worked hard, and now we have repository on Github with 3D files and Manifest file, which explain why I do this project.
3D model
05/29/2016 at 12:31 • 0 commentsToday I made 3D model of the watches. Pictures here. I have uploaded files in .STL and .IGES
Now you can see main feature in design - buttons on top and bottom of the case. In my opinion, this more user friendly position. -
Designer problems
05/25/2016 at 18:52 • 0 commentsToday after few hours of brainstorm, I have a vision of the watch case. First 3D models you can see at the pictures. Now I thinking about rectangular forms with rounded edges. Early I planned to make watches round, but all displays what was found on the market have big frames around active area. In this reason, round case must be a bigger and small active area looks a little "clumsy".
Starting point
05/24/2016 at 19:45 • 0 commentsAnything goes, work in progress. I design a case and pcb in same time. This is a bit tricky, but not less interesting. At the start of the project I planned to use TFT display, but few days ago my decision is changed. Better to use uOLED display, because it help to reduce power consumption in monochrome mode.
