Completed instructions to vary the speed of the Snap Circuits motor
06/01/2016 at 15:10 • 0 commentsCompleted instructions to vary the speed of the Snap Circuits motor using the modified transistor and variable resistor circuit.
Able to us transistor to vary speed of spinning mirror
05/31/2016 at 15:26 • 0 commentsFound a circuit in the Snap Circuits Motion manual to vary the speed of the Geared Motor (Project 49 on page 34: http://www.elenco.com/admin_data/pdffiles/753134.pdf). Will post instructions on the circuit build as time permits.
Still looking for suggestions to attach construction toy gears to motor axle.
05/31/2016 at 12:44 • 0 commentsStill looking for suggestions to attach construction toy gears to motor axle. I you, dear reader, have an idea for a solution, please comment.
Successfully spun the mirror
05/27/2016 at 13:29 • 0 commentsI think the next thing to do is to control the speed of the spinning mirror. This can be done mechanically with different sizes of pulleys.
Steve Schuler
