The device sends its voltage and temperature to my emoncms server.
Emoncms (https://openenergymonitor.org/emon/) is an open-source web-based software for monitoring home power, temperature and sensors. This is a central part of my DIY home automation system.
Emoncms exposes an API, so reading / posting data to the server is very easy.
Here is the piece of code I'm using :
#define emoncms_host "1.2.3.4"
const int emoncms_httpPort = 80;
String emoncms_apikey = "YOUR_API_KEY";
int node = 1;
void postEmoncms() {
// run only if the ESP is connected to a network
if ( WiFi.status() == WL_CONNECTED ) {
WiFiClient client;
if (!client.connect(emoncms_host, emoncms_httpPort)) {
Serial.println("Post to emoncms failed");
return;
// We now create a URI for the request
String url = "GET /emoncms/input/post.json?apikey=" + emoncms_apikey + "&node=" + node + "&json={2:" + temperature + ",1:" + vcc + "";
client.println(url);
client.print("Host: ");
client.println(emoncms_host);
client.println("Connection: close");
client.println();
client.stop(); //Stopping client
Serial.println("Post to emoncms : success");
else {
Serial.println("Post to emoncms : not connected to internet");
Of course, this function shouldn't run constantly in the main loop, but should run on timed intervals. I'm using RBD_Timer lib (https://github.com/alextaujenis/RBD_Timer)This function runs in the background, so there won't be any screenshot this time !
