Well, I thought that's what the description was for, but this seems nice.
The box was designed around the idea of leaving it at work/school do do my bidding in low usage times. It's got 12v in (on two RCA jacks because I think it looks nice and it's an accessible input method) so I can hang the whole system of a molex cable or my works cutesy little solar system, pumped directly into a 50W chinese DC-DC step down converter, and then bumped back up to 12V with a step up for things like fans (because I don't trust the input, on solar it could go from anywhere from 10v to 14v). The 5V goes directly into the GPIO pins of the Pi, because the barrel jack's a cumbersome pain (wouldn't have had to ride my bike to Jaycar had I realized this at the start), it also uses a USB OTG adaptor as a micro usb breakout to power the router, a custom power cable runs the 2.5" disk, and there are two female ports on the front connected to the 5v source with their data pins shorted.
There's a female ethernet jack on the face of the box wired up to the router, then the lan connection on the router is connected to the Pi through a flat ethernet cable.
Another USB OTG adaptor and a female micro USB breakout board is used as a makeshift male usb breakout connector, and is wired up to the same thing, essentially making a really thin (male or female) to (male or female) usb cable. This is in turn wired up to a USB to SATA adaptor connected to the 2.5" disk.
I planned for some fans but at this point the box is rather cramped (and they haven't arrived yet) so they can wait.
More details in the logs.
And all working!
USB ports wired up.
Magic Robots
Dimbit
Retroplayer
fpp
Is this information useful?
