So after spending way more time sitting unfinished on my workbench I made some more progress towards actually finishing things. The code has been updated (and pushed to Github) which allows for options of showing/hiding the display of seconds as well as a setting to force overlap of the hours and minutes digits anytime it's possible as opposed to the previous behavior which only overlapped when there wasn't enough room to display them separately. I also did some code cleanup to do a better job of processing the encoder turns when dealing with partial turns and to account for switching the encoders and knob from active low to active high.
Things still left to be done:
- Finish frame
- More code tweaks
- Add option to display current base
- Utilize LEDs in knob (requires some HW cleanup/debugging)
- Possible add option for date info
- Draw up schematic of control board
